2014-15 silverado front bumper cap
I have a 2014 silverado double cab WT 4x4 and I was wanting to know if there is a way to get a chrome bumper cap for it.  I have switched the grill out with that from a LT, replace the plastic bumper cover with a painted white one that came with the grill, its currently plasti dipped grey to blend in with my trucks Grey color, just had it detailed and dents pulled, been putting off having the front bumper cap color matched due to work schedule and the fact that my silverado has had almost every issue on here reguarding the 14 and 15 models from power steering issues due to faulty ground to my ac being replaced 2x now.  Still love the truck, any idea if I can get a chrome bumper cap on this truck?
Just hit 87k miles, updates are
new NGK iridium spark plugs, original fouled at 84k miles
Bilstein Shocks
Rough County leveling kit
Stock 17in alloys for winter weather in toyo ATs
Hankook dynapros  on 20in GMC sierra wheels, swapped out center caps to chevy caps
Duralast Platinum Battery
Starter
Battery cables
Tow Mirrirs, with harnesses
(Rear pinion seal, Torque converter, Transmission mount, under warranty for knocking noise when shifting down.)
High pressure line mount for AC, apperent fix in 2016.
When windshild was being replaced, removed some of the sound dampening material around the grounds and it fixed my electrical issues with my powersteering.
Don't forget the  Front & Rear Axel , transfer case , transmission  and anti freeze ?
with a few months left in my powertrain warranty I hope all of my issues are resolved for the time being, I have a limited 20yr 250k mile extended powertrain warranty so hopefully that will cover most issues.
Bilstein Shocks
Starter
Battery cables
Not sure if it exists, but you could check with this company, Bumpershellz.
