Misfires, Noises, Emisions, Codes!
Few months ago I had misfire and code for both misfire and oxygen sensor. Had to drive home with it misfiring.
I narrowed it down damaged wiring at my upstream bank2 sensor... I repaired the wire and left the old sensors in.  Voltage was ok afterwards the codes went away.
However, at this time I was getting a rattling noise. I thought it was the converter, that maybe a piece broke off or it was damaged when I drove it home while it was missfiring.  However, I could not manually produce the sound while hitting it with hammer. After a few days, the rattling  went completely away!!!
I have driven it for about 100+ miles since and there has been no noise or codes. During that time, the only issue I had was that it rough idled after filling the tank for a few moments. This only occured once so I didnt think to much of it.
Today I get P0430, efficiency below threshold bank 2. No other code popped up and there is no noise and it appears to be running fine.
Do you think I should replace the sensors? Or is it likely the cat is bad?
Can you venture to guess why the noise which I thought was the cat completely disappeared?
What the best way for me to diagnose if this is the sensors (which I can replace in my driveway) or if its the cat, (which I would have to pay to get welded properly)?
Thank you.
What the best way for me to diagnose if this is the sensors which I can swap myself or if its the cat, which I would have to pay to get welded?
Thank you.
What's the year make a model of the vehicle?
Without knowing those, here are a few things you can check.
A P0430 can be checked with a back pressure gauge. That's the best way to tell if it is a converter or the 02 sensor. I actually just picked one of these up to do a review on my channel and I actually like it better than my snapon and it's 100x cheaper. https://amzn.to/2WFcCyh
Also, Fix your cats. Don't cut them out. The truck works better with than without them.
The noise could have been a collapsed lifter if its a 2007+ AFM truck but without the y/m/m I am not sure.
Its a 2000 silverado  4.8
Cant cut em', wont pass the test.
I will have to research the pressure test. However, if i have get the cats replaced, im guessing i would do the o2 sensors too at that time. So maybe it makes sense to just swap out both bank 2 sensors at hope that solves the prob.
Is bad cat and bad sensors the only causes of po430?
    mighty K20
    mighty K20
  • Who's Online   6 Members, 1 Anonymous, 519 Guests (See full list)
