A/c diagnosis help
So last summer my a/c went kaput.  I recharged it and it was ice cold like it used to be.   I noticed when I tried to recharge it a little rubber ball went flying out of the Schrader valve and I have no clue where it went.  I’m assuming the valve was leaking and that’s why it did that.
i haven’t had time to address it since winter hit but I want to get this fixed before summer hits.   I noticed now the a/c is bone dry and the compressor won’t stay on.  I just tried to recharge it and it’s definitely still leaking real bad at the valve.
Other then replacing the Schrader valve, or maybe tightening it, what else do I need to do?
Should I service all of the valves?
02 Silverado ext cab 170kmi.  5.3 v8  4x4
Little ball is likely from the gauge set where it connects to the shrader valve.
Leak could be coming from anywhere. You will need a leak detector to find it, and that will require the system to be under pressure (filled).
And if the system is bone dry, moisture is probably in the system. You will need a vacuum pump to remove the moisture
Yeah, the valves tend to leak, and the little rubber ball thing you're talking about is probably the seal in the high pressure fitting (see picture below). I replace these fittings a lot. You can remove the high pressure fitting with a socket, but I always recommend using the proper tool to do it. Hope this helps, Here is what you need below.
Here is the fitting you need.
High side - https://amzn.to/2OEg5ul
Low side - https://amzn.to/2K4tWLI
High side socket - https://amzn.to/2VgkO7I
Low side tool - https://amzn.to/2VddxFW
  • 1 month later...
You'll need a vacuum pump and a full set of guages. Some of the parts houses have them on a tool loaner.
After repairs,
- connect vacuum pump to the yellow house and hookup both high and low.
- Close high valve on the guage manifold, open low side
- run pump until pressure drops to -25 to 27.
- close low side, disconnect pump
- change oil in the pump (first round of vacuum pulls moisture, oil and particulates which limits the pump from achieving highest vacuum)
- reconnect pump, start pump, wait 15-30 seconds and open low side slowly.
- wait until pump achieves -29.5 to 30.
- stop pump, close pump valve, close low side.
- monitor vacuum for a few hours, overnight is best.
- if vacuum holds, proceed otherwise repair
- connect Freon tank to yellow hose, bleed air from yellow hose thru shrader on manifold until Freon flows
- open low side to allow Freon to replace vacuum
- initial load of Freon this way will usually achieve enough static internal pressure to satisfy the low pressure switch allowing the compressor to run
- with compressor running, add Freon per specification
- disconnect guages per instructions (usually, with compressor on, turn off Freon can but leave connected, close high side at the connection near engine, open high side at manifold so excess Freon can be pulled into system, closer low side at engine, disconnect low side, stop compressor, let sit for a couple of minutes, disconnect high side, disconnect Freon can)
  • 3 weeks later...
Thank you!!  So far several days of driving in hot weather and AC still ice cold.  I hope it gets me through to winter.
my system was empty of Freon with no pressure and took two cans of refrigerant.   Pressure seemed good and I should be right in the operable total suggested weight of r134.  None of the valves are leaking.
 I’m glad I used safety gear because when I disconnected the high and low pressure sides and went to release the manifold pressure so I could return it, some Freon was still in the little manifold hoses and would have cold burned my hand.  I hate having any of it discharge even just a little bit but I imagine the stuff left over in the manifold hoses is unavoidable?  I was surprised how much was in a foot or so of hose.
Newer/better guages have shutoffs located at the end of the hoses that allow locking in the Freon into the hose and limit the amount that escapes on the disconnect.
Also, to minimize storage pressure and to minimize chance of blowing the seals inside the guage quick connect, do the following:
- engine running, ac on
- shut off high side
- open both hi/low at the dial to allow drain of t
Hi line
- shut both hi/low at the dials
- close low at the end near valve
- turn off ac, let system equalize
- disconnect hi
    tararebecca
    tararebecca
  • Who's Online   2 Members, 0 Anonymous, 484 Guests (See full list)
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
