I have a 2018 Silverado 2500 HD LTZ Duramax.  The truck is pretty much fully loaded and I don’t like the center console.  The 1500 truck I used to own had the front bench seat; actually two buckets with a center seat that the back can fold down to be a arm rest/console.
Has anyone converted the center console to the front “bench” seat?
I would like to make the conversion but am wondering what’s involved and are the parts just a bolt on?
Any link to anyone that has done it too would be appreciated.
Thanks
The middle is the only difference, you may have a subwoofer that may need to be relocated.  I have the middle seat, the best part is being able to pass thru and the middle seat bottom is a big lockable storage box.  That and the top box makes it really nice.  In the top box are 2 USB ports and a 12v plug so there is wiring there too.  I'm sure it can be done but it may cost a lot.
Thanks
Maybe you could find someone who wants to switch. Last year I wanted to switch to the center console you have, I have the bench seat, but couldn't find anyone. There are some guys on here who have done the conversion.
Sent from my SAMSUNG-SM-G935A using Tapatalk
advertise a trade,   you will quickly get responses I am sure.
I’m currently in the process of this exact swap, so far it’s been a direct bolt in. The console and jump seat use the same mounting location, there is a dash piece you will be missing and some trim can order from gm that fills in where the console was, it was about 100 shipped, that includes a 110v plug and cigarette type plugin if you already have it. Still working on the wiring, but I was planning on removing the connector on the console and extending the wires to run under the carpet to the jump seat, I will have one extra dual usb that was on my console I’m planning on relocating to the glovebox
Curious how this turned out I was looking to do the same thing but can never find a console that doesnt cost an arm and leg
  • 4 months later...
Does anyone have any idea if this swap will be possible on a 2020 2500HD?  I've got a family of six.  Getting the bench seat from the factory severely limits what options you can get on the truck.
Christian
Thanks
I would definitely trade you for your center console for my center seat! If interested let me know!
have you sold your center console yet?
  • 5 months later...
Christian
What a joke gm wont let us family of 6 guys order a nice truck with the 60/40 front. Very stupid business! I was trying to build one one the web site and if you add anything cool it gives you that stupid “must remove 60/40 bench seat” message ? I’m a die hard gm guy but that’s idiotic
I found a Trim shop in Bozeman, MT that was able to swap my console out for a factory bench seat in my 2020 Denali 2500. He documented the process so that it’s easier the next time around. Let me know if you want his contact info. He’s good stuff.
What’s the plan for the missing carpet where the console was?
The trim guy said he could replace that portion of the project but I decided to not do that.  The GM rubber floor mat for bench seats covers that area completely.
Christian
I think the subwoofer and other electronic boxes are mounted under center console. That's why certain options aren't available with the bench seat.
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
