TRail Boss XM Install
On 9/17/2019 at 6:03 PM, dctackett10 said:
Just finished hooking it up.  Installation was easy. Ran 2 wires to ground and the other 2 wires to the cigarette lighter fuse. Hardest part is just deciding where and how you wanna run all the wires.
Also so don’t think you would be able to use the factory antenna.
Also you get 3 free months.
so u didnt use the usb ?
On 4/11/2019 at 2:43 PM, JJL said:
Instead of adding the XM screen you can buy this kit online and integrate XM into your factory radio as well as saving pre sets. Super easy to install also
https://www.vaistech.com/product/gsr-gm03-w-tuner-kit/
anybody install this? is there a usb in the back of the radio that I'm not seeing? or do I have to have a cable running to the usb in the front?
5 hours ago, dctackett10 said:
Yes. You have to use the USB port in the front
nooooooooooooooooo  !!!
thanks...
  • 5 months later...
So what I am going to do is get another USB outlet like the factory one,  plug it into the factory harness and tuck it in behind the panel,  and using the VAIS aux USB outlet and cut the wires off there outlet, and tap into the original USB outlet still installed in the panel.   So I will still have that port for charging.   One thing to note though is you will loose android auto functions,  which is kind of a bummer because occasionally use it to project maps or waze,  but xm is more important soooo.   I could use the xm app but it is not as seamless and does not work if you are in an area without cell service.
  • 1 month later...
Another option for XM radio is the phone app.  I have the app on my phone and can stream it all from Bluetooth or if my phone is plugged into the usb.  Just like your waze or music it can be ran from the trucks display.  Works great.
    C. Hart
    C. Hart
  • Who's Online   1 Member, 0 Anonymous, 425 Guests (See full list)
