Tailgate lock
RP53
i have a 2017 GMC sierra 1500
is there anyway to disable the tailgate lock  i don't have a cover so it is useless for me
Why would you want to make it easier for some low life to steal your tailgate.
Just my opinion.
Sent from my SM-T830 using Tapatalk
Pop off the access panel on the inside of the tail gate,
you can then see if you can unplug it, or remove the lever that is activated to lock unlock it.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 307 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
