01 silverado transfer fluid change
Ive got 01 Silverado that I have been working on and was about to change fluids. its a 5.3 with floor shift 4x4. Only thing found online is if its auto or button 4wd then use differ type and if floor shift then use auto trans fluid. Is this correct and how much does it hold? Does anyone know of a page that has all fluid specs. on this model truck. thanks for the help
Yes,  That will cover basically all that you need for fluid changes.  AMSOIL ATF for the T case.  The new squeeze pack makes changes a breeze and no mess. :)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
