On 6/18/2019 at 2:56 PM, cal19 said:
I’m curious to know what the difference is with the AT4 Kit vs Trailboss Kit. Anyone have an idea?
I posted this in another thread today....on the difference...
Sounds like horse sh#t to me....  I'm at work right now an I have a 2019 AT4, and a coworkers 2019 TB. I just looked under them and same control arms and same strut part #s...
Motofabs site list same part # for both too...
Link?
Sent from my Pixel 3 XL using Tapatalk
On 6/17/2019 at 11:08 PM, josephearljones said:
Of course. Right after I install the motofab 1.5
Any ball joint or cv axle issues .. I am wanting to install the 1.5 RC on my trailboss..Any pics
Edited by Jp sierra
On 6/26/2019 at 9:10 AM, thsoccer3 said:
Here is my research:
1). Dealer installed Pro Comp 63235 for $875.  Dealer says they will stand by factory warranty if they do the work, but Pro Comp says this kit is not rated for the AT4.
2). Local accessory shop installed Rough Country Sku: 1318 for $350.  If the dealer were to void warranty because of this mod, RC's website fine print says the owner is responsible for having a dealership fix the truck, and then contacting Rough Country to prove the malfunction was caused by the lift kit.  This raises caution and sounds like the beginning of a "blame-game" or "run-around" to me.
My end goal is to level the front and go with 295/65/20 (35.1") or 295/60/20 (33.9") Nitto Ridge Grapplers, but my concerns are warranty and sacrificing ride quality.
Any thoughts?
Take this for what it is- But local dealer said levels will not void warranty- Unless possibly you don’t have it aligned and there is an alignment issue- They wont cover a ball joint/hub etc in that case. Dealers are all different and some are bigger assh*les than others.
  • 11 months later...
  • New Member
  •  1
  • 4 posts
I'm about to install the RC 1.5 on my 2020 trail boss the directions say to remove the skid plate and unplug the steering rack 3 plugs . I was just wondering why ? I see people installing other kits and they don't do it but their basically doing the same thing removing the strut. Some guys don't even undo the axel to get the strut out....I don't want to do unnecessary things but I want to do it right ......... Thanks
  • 8 months later...
On 7/13/2021 at 10:26 AM, Dan Pemberton said:
  • New Member
  •  1
  • 4 posts
I would like an update on how your process went with your leveling kit. I just purchase the rough country 2" leveling kit for my 2021 GMC Sierra AT4 and i'm debating if I should purchase new control arms to go with it.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 868 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
