On 1/20/2020 at 12:50 PM, Whatnext said:
I have just had the same problem on my 2018 silverado with 40k on it. It happened the first time 3 weeks ago. drove it, stopped and it wouldn't start. I jumped it with a jump box and then cables just to make sure.. The dash, lights and radio all come on as normal until i go to the start position, then everything goes off/black and 1 click. As i let off of start position the dash all comes on again. After watching some youtube videos and 2 hours later, i went out to the truck, reached under the passenger front fender and gave a wire a shake (thinking it went to starter) got in and it started.. Probably a total coincidence but never the less it was running.  Then 3 weeks passes and it does it again. I waited 2 hours, gave the wire a shake again, and nothing. Got it towed in and luckily it still did not start when it arrived at the dealership and they diagnosed the starter. Here is the kicker, there are no starters in North America and it may take up to 3 weeks for them to get one!! I think they have a huge problem that they aren't telling us!! I work in the auto industry and i know as a parts supplier the pipeline is always full unless there is a big big issue...
    This sounds SO much like my problem.I have a 2018 Silverado with 42k.The problem generally happens when it is less than 25 degrees.If I keep trying to start it,it has always started.But sometimes it takes 6-7 turns of the key.It has been to the dealer twice,and it always works fine for them.They told me they have no ETA on a new starter.Kind of a joke really.I already had changed the battery a few months ago,thinking it was that.I keep checking this forum for this topic to explode.Most 2018 owners don't have 40k miles yet.But just wait!
Edited by 442olds
Same for my 2018 with 25000 miles.  Truck sat all weekend and worked fine Monday morning.  Went to the store for 10 minutes, came out and just a click.  Turned the key about 15 times, wiggled wires, did a dance and started right up.  Put it in the garage to inspect, wouldn't start.  Battery was fully charged, but I still charged overnight to be sure...wouldn't start in the morning.  After about 20 turns with the key, starts right up and I took it to the dealer.  It is important to note that the dash, headlights, interior lights all seemed to work fine with no messages about the battery.  So now it sits at the dealer with the starter on National Back order!  He is hoping it will be in within a 1.5 weeks.  In the meantime, my loaner is a new 2020 loaded Yukon.....I can live with it for now, but miss my truck.
Edited by cansled
They found a starter for mine, installed and on the road again.  My personal opinion is that they have a huge problem with the starters but don't want the expense of a recall. And, between keeping the line supplied and supplying replacements, their supplier is not tooled up for the huge volume... btw, I work as a supplier in the auto industry.
Interesting to hear that the starters are still on back order, this summer when my 2018 starter took a dump, local part stores couldn’t get them.
   My 2018 Silverado is out of warranty.The dealer said that the starters were on backorder,but I was able to locate one on my own.I asked for a quote on labor to install it,and my local Chevy dealer said they could do the job for $288.
 I thought that seemed rather expensive.Upon installing it myself,I found that you can easily get the old starter down in less than 10 minutes and be complete with the job in about 1/2 hour.
 So if you need a starter and are out of warranty,don't get ripped off by your local Chevy dealer.
So far so good with the new starter.
Well, just a follow up on the starter situation - which I’m sure is no secret any longer - within two weeks time I personally knew three people with these trucks that had their starters go (all under 50,000 miles). Three of them towed to the dealer. Two of them could not get the part. Guy at one dealer said, this is the worst thing he’s seen from GM in 25 years...the amount of failures and lack of parts.
The starters are not sealed properly. They leak. Moisture gets in.
I believe there’s a recall for it now, so if you paid out of pocket, GM should reimburse you. Don’t quote me on this. Lol.
I have this exact same issue! 2019 Silverado 5.3L and just over 40k miles. Also got a new battery 2 weeks ago which wasn't the issue. New starter fixed it.
2017 Silverado 5.3. Having similar issues here. Starter was sounding slow for a couple of weeks but it never failed to start. Figured I’d go for a new battery since I needed a new battery for my boat anyway and if that wasn’t the problem I’d just use my old truck battery in the boat. Changed the battery, started truck, worked perfectly. Turned it off to try a few restarts ........ click! Checked everything and noticed the starter wires and studs on the starter were looking a bit rusty so I took the starter off, disassembled and cleaned everything. The starter showed no signs of wear (brushes, bushings, reduction gears). Worked perfect. Starter was turning much faster and sounded normal again. Today I accidentally left the key on and noticed the warning about the battery saver feature was active. It started anyway........ once! Then back to the same “click” I was getting after the battery change. A charger on boost didn’t make any difference either. Gonna wait until tomorrow and check for voltage at the small wire while someone tries to crank it. If voltage there, I’ll check the feed from the solenoid to the starter. I’ll post my results.
Edited by Cansomike
Problem solved. GO BACK TO THE BASICS!!!! Don’t just go ahead and throw on a new starter! Of course that may fix the problem because you’re also fixing the connections at the same time!  A bad connection on the solenoid was the culprit. When I removed and overhauled the starter the first time, there was one nut that wouldn’t turn and I didn’t want to risk breaking the stud off so I left it alone. Today I got someone else to try and crank it and I just happened to be looking at that same nut and when he tried it I saw a small spark. It was the nut that would normally hold the starter cable on if they didn’t have that stupid plastic/metal “adapter” on there. I had to cut the nut off and run a thread chaser over the threads as it was arcing there and messed up the threads a bit. Just one more connection to corrode and fail, imho!
Edited by Cansomike
I'd keep an eye on that, that shouldn't have sparked unless it was a loose connection. That's generally a fool proof connection. Big wire, low resistance...a few people have complained of a spark at the starter. Was the connection loose?
The nut was blackened and so was the stud. I’d say it was loose enough to cause some heat (resistance). While cleaning it I could see where it made marks from arcing. The threads were messed up a bit from arcing as well. It’s not the nut that holds the cable on, but the one that holds the adapter onto the solenoid.
Edited by Cansomike
  • 8 months later...
On 7/2/2019 at 7:31 PM, Beer Belly said:
I had the same issue, but intermittent and the dealer kept pointing at the battery, meanwhile I was telling them the battery was fine, check the starter. They would not budge on thier diagnosis, even though I told them "When it does start, it cranks and starts strong", so I caved and paid for a battery, it was 3 years old anyhow. 2 hours later, no start, so I called them and they were sending a tow, I went outside and she fired up and drove her in. I told them once again "It's the Starter, check the damn Starter !"....his answer "Did you ever think it might be the Alternator ?".....he must of noticed my puzzled look "How the freak does a bad Alternator cause an intermittent no start ?".....to shorten an already long story......yep, new Starter
Oh my goodness. Here I sit, stranded (at home) with a 2018 we bought certified a few months ago.  First time, dealer replaced battery.   I challenged my husband that it wasn’t a battery issue - the truck took a lot to start.
Randomly I’d have the issue and the suggestion was to see if it would start with the key. Remote start.  Okay, it will but that makes no sense.
Truck packed up.  All set to tow a horse about 100 miles and <click> nothing.  Tow truck on its way.  I’m smiling through my pissed-off real feelings because I need the dealer to fix it tonight.  They said they could get it in as soon as we arrive.
I’m going to smile and suggest they replace the starter (under warranty) because my brand new battery I bought from them last month isn’t dead.
Oy vey.
DebM
Did you get the dealer to replace the starter? If so have you had any issues since? I am currently dealing with this issue too on a GMC 2018 Denali with a 5.3 w/46K miles.
Thanks!
Add me to the list.  Except I think we're zeroing in on the issue being starter heat soak as the truck will only have starting problems on extremely hot days.  And after a no start situation, if I let it cool off for about 10 minutes or so it will start up again.
https://www.knowyourparts.com/technical-resources/starting-and-charging/starter-will-not-crank-when-hot-heat-soak/
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
