  • 4 months later...
So I am having the same issue and its driving me nuts trying to figure out whats wrong with it.
2017 Sierra 4X4 elevation
75K miles
Added demon eyes and tail light bar
Does the one click no start at least once a week. Started it this morning, went out later and one click no start. Lights seems bright and battery tested voltage was 12.2V. Took to O'reilly's and they said the battery (1.5 years old) was good, alternator is good and starter is good. But they are testing the starter when its working, not just doing the one click nothing.
I think its strange that it does this, but as soon as I jump it with a running car it fires right up. Tested jumping with a non-running car and it does the one click nothing. The car has to be started.
I was told its a loose or corroded connection because as soon as I connect a running car it fires right up.
When it did it this morning I tries just connecting negative from wife's car to negative on truck, nothing change, trying to confirm whether or not I had a bad ground.
Why does the truck not start on its own, but as soon as I connect a running car producing 14 volts it fores right up?
I have a battery tender connected to it and will do so for the next week as a test, or when it starts the one click nothing. If the truck does the one click nothing, this tells me it is not the battery.
Edited by stickerbush1970
adding more information
  • 1 month later...
2018 Silverado 5.3.  Trying to start it, 1 click, and nothing. Boosted it once and worked. two weeks later, same problem, moved shifter from park to drive and back to park and it worked. Suspect starter or starter relay. Will keep you posted.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 720 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
