Dome lights won't come on
So trying to get some clues in what might have happened. I left my truck out in the rain today and when I just started it tonight to go home from a friend's house, I noticed the dome lights didn't come on. The button is set to door. I tried the on option and nothing. I am able to turn on each of the individual dome lights if I like in the interior but they won't come on when the door opens. Any idea what it could be from? Where is the fuse for the lights kept? Could it possibly be the fuse? I know for sure it worked 2 days ago. So this is recent.
I also noticed that my left turn signal is flickering again. I changed to led and it happens with the resister. The odd thing is it just started again today. Also wanted to make note I added the footwell lights as well but that was over a year ago and I still see that's correctly plugged in.
Any advice would be appreciated.
Sent from my Pixel 2 XL using Tapatalk
I am guessing but I believe you've identified the potential culprits.  I'd recheck all of your aftermarket wiring connections or new grounds you made in the past. Simple visual inspection may not be enough.  I'd then look at the door switch.  I have no idea what this involves but Google is a great place to start!  The fact that your interior lights work would rule out a blown fuse, imo.
I did that and tore down all my attachments. It ended up being the magic hat connection I had. Which it is odd since it's been there for years work no issues. But it is spring just fine now.
