Tire sizes.
It is time for tires. I have a 2016 silverado z71 I’m on 305/65r17 deegan 38 mt’s on a set of method’s and a 2 inch level.  Has anybody had any luck with a 295/70r17? Also does anybody have a preference between toyo open country rt’s and nitto ridge grapplers?
Ridge graps, all around a good tire seen them go thru sticky situations others probably wouldve had problems in
I’ve got 25,000mi on my ridge grapplers and really like them. They still have a lot of life left too.
try customoffsets.com they have a huge gallery of trucks that all list their lift, tire and rim sizes. It’s how I picked out my setup. It’s not just brodozers and mall crawlers.
That’s what i ended up doing i’m just not sure if i trust peoples input they put on there all the time haha
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
