So after countless searches, I was not able to really find anything useful about the ride quality and stance of the new GM 2” lift.
I went ahead and pulled the trigger and put this kit on my High County.  I’ll try to give y’all as much detail as I can regarding stance, handling, and overall ride quality but for starters, let’s just say I’m not a bit disappointed!
As most of us know, Chevys have quite a bit of factory rake. This kit will NOT cure that as it raises the truck 2” all the way around.  However, my specific truck did not have a ridiculous front end squat to begin with so no other mods were necessary to get the stance I was searching for. But if you want it leveled, then you’ll need to add a level kit the lift kit. Otherwise, your truck will sit exactly like a Trail Boss. Overall, the stance is slightly aggressive but not overdone as this is a High Country, which will most likely never see true off-roading.
Chevy suspensions...IMO tend to be mushy and bouncy. Well this kit changed that for my truck. It now rides exactly like the Trail Boss which is what I was looking for.  Instead of several bounces after going over swells and dips in the roadways, the new suspension unloads and stabilizes extremely quickly. This also bleeds over into the overall handling...which didn’t change at all. The truck still hugs the road tightly and even with the rear raised 2”, there’s no skipping of the rear when cornering. If you’ve ever had other lifts, you should know what I’m talking about.
Next step is to add some All-Terrain tires and get rid of the junk street tires GM puts on their trucks, most likely 285/50/22. But for now, I hope this little bit of information can help someone make an educated decision.  Let me know if you have any specific questions...glad to help!
Edited by Bowtie Family
Typo
Thank you!
Lift was $1295 and my local dealership installed it, reprogrammed power steering and front cameras, and aligned it at no charge...hellava deal!
Getting 285/50/22 Ridge Grapplers put on this afternoon so I’ll post updated pics.
Typo
Sounds great!  That's not too bad, especially if it's an installed price.
Installation is not included in the price of the lift, but I know they guys really well and they did it as a favor. Generally it would cost several hundred for installation.
Thanks for posting this.  I'm still trying to decide what to do with mine and this is something i needed to see.  I'm curious to see how it looks with different tires.. or real truck tires, not the street tires that come stock.  Looks really good.
Dealer put mine on before I picked it up
Worth every penny love it
Ryan B.
I’m currently getting 285/50/22 Ridge Grapplers put on. I’ll post pics tonight when I get home.
I’m thinking that’s just about the largest tire I can run without rubbing...I absolutely HATE rubbing.
I was was torn between the Ridge Grapplers and Terra Grappler G2’s because I didn’t want to take away from the sleek style of the HC, but the Terra’s I believe would have been to boring.
My thoughts on the tires exactly.  Thanks
Did you drive it with the stock suspension before picking it up?
No sales lady drove before and after before I picked up. Truck was 5 hrs away in Detroit
Ryan B.
Ryan B.
You should go drive one with the stock suspension...it’d make you appreciate the upgrade even more.
I drove a high country before ordering. Personally I think the 2” is perfect height for these trucks. Similar to what I did with my 2010 (2” level and 3” rear blocks)
285/50/22 Nitto Ridge Grapplers
No rubbing at all!
No rubbing at all!
Looks great!
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
