Door rattles
I have a new 2003 Silverado ext cab. I have taken this into the dealer for noise's that seem to be coming from the drivers door aproximately at the height of my shoulder. They said that the speaker needed to have some parts replaced, which they did. The noise is still there. I suggested that perhaps the door wasn't adjusted properly. But they said that this was O.K. Noise isn't real loud. I notice more at low speeds and on road that are not real smooth. This is annoying to me,
any suggestions?
I'd check to make sure the rear door is shut tight. When they are new they can be stiff, and although they appear to be shut, they aren't. Also the rear door could be out of adjustment, or the front latching mechanism needs adjusted.
Moldings are known to make alot of weird noises... I'd spray the moldings around the door with a silicon spray or di-electric grease and see if the noise goes away.
Good Luck, and welcome to the forum!!! :thumbs:
I hav to agree with shanners...I am 90% sure it is the moldings around your door. Here is a link to previous posts concerning the same issue...I had it for the 1st year I had my truck and it annoyed the hell out of my. It sounded like a piece of s**t, but once I fixed the problem, it felt like a brand new truck..
http://www.gm-trucks.com/forums/index.php?...ther+strippings
This is what I posted in that post:
It is absolutely the weather strippings in the door seals. What you need to do is go to Wal-Mart and buy a can of STP silicone grease (blue can, red top, kind of like a spray paint can.) Pull your weather stripping off (driver and passanger side)...I am talking about the strip that runs along from the front fenders, up the windshield, and then across the edge of the roof, then down behind the rear doors. Wipe them off with a dry rag (to get the dirt off) and then SOAK both sides of them with that stuff. It is "greaseless" and odorless, so don't worry. When I say both sides, I mean the side you can physically see, and the side that actually touches the truck. I had mine in the shop 3 times for that problem...and the truck sounded like a piece of s**t from day 1. I wanted to get rid of it because it sounded like it was 30 years old from all the noise the cab made. All the dealership did was spray the side you can see. After a year of living with the noise, I started thinking that maybe it was the backside of them. I soaked them, put them back on (real easy to do) and haven't had a problem since. That was like 3 months ago, but I'll do it every 2 weeks if necessary. It feels like I am driving a brand new truck, even though it is only 1 1/2 years old. Good luck, and I feel your pain!!!
Then..
It took all of about 10 minutes to do this. They pull off real easy...and putting them back on isn't too hard either. When putting them back on, start just above the windshield, and then slide it down behind the fender (be sure to note their position before taking them off and you'll see what I am talking about). Snap it back on along the windsheild, along the roof, then down behind the door. I am not mechanically savvy at all, and I am not a big fan of ripping things off, but it was very easy. I did it like 2 months ago, and I have had no problems with wind noise, leaks, or the strippings not staying on. I bought the GM dielectric grease, but I did not use it. The little tube was $14 from the dealership, and the can of silicone grease was really cheap at Wal-Mart. The way I figured out it was the strips making the noise was that I pulled them off and drove it around the block. It made my day...it was so quiet!!!!! Anyone that thinks their truck is a POS because of all the noise the cab makes needs to try this.
I will say that it has been a few months, and that the noises are starting to come back. I plan on doing the same thing again this weekend. I don’t mind this 10 minute procedure to drive a quiet truck!!!
Good luck.
:thumbs::thumbs::thumbs:
Thanks for the feedback, I did spray the moldings with silcone spray and it did help quite a bit. I plan on removing the moldings and apply with silcone grease and was suggested. My son has a 2000 Silverado extended cab and he plans on doing the same. His has less noise than mine. If this still is a problem I will take my Silverado in and have the door adjusted. Once again thanks for the replies.
My '02 HD Ext cab had a rattling doorset and wind/air leak on the driver's side along the top of the driver's door only. You'de notice the air leak almost all the time...especially when driving into the wind. The doorset rattle was most noticible over washboard pavement. I looked at the catch loops top and bottom...almost all the way out! Never adjusted. The pass side loops were all the way in and suffered from no doorset rattle. Loosened the bolts and put both loops all the way in...SHAZAM! no real noticible difference in the effort to close them but...80% of the wind noise and 90% of the rattle is gone! Those weatherstrips are way soft . The next step is to use an extension on a can and blow a little spray foam into the weatherstrip along the top of the front door where I still have a little air leak under certian conditions. This will give the candy-azz weatherstrip a little more "body"...a little less "collapse" and more than likely finish off this annoying problem. This may or may not have something to do with your issue...but it may help somebody. I can't imagine I'm the only one! :D
I washed the truck this weekend (including cleaning around all the door jambs/sills) and then applied a coat of dielectric silicone grease to the all the weather stripping (i'd done this once before, but hadn't noticed the reduction in noise then). Man, what a difference. I'd say it reduced 90% of the rattle noises I heard from the cabin (now, the dash rattles are really annoying me since I can't hear anything else). I could have sworn those rattles were coming from inside the truck, but I guess not. If you have rattles, try this cheap, easy fix first. Either way, it's good for the stripping.
    needafix
    needafix
  • Who's Online   6 Members, 0 Anonymous, 584 Guests (See full list)
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
