Hey guys, I have a 2001 1500HD 2wd. 32k original miles. Im going to drop it but wonder what you guys have done. Don't want to do any cutting just a complete bolt on kit. Also this thing is 8 lug so what kind of wheels and what size are you guys tucking under these lowered HDs? Thanks! New to this forum but not new to these trucks.
If they offer drop spindles up front for those trucks I do that over cranking the torsion bar keys down.
The rear they sell lower shackles and lowering rear hanger. You just have to cut/air hammer the factory rivets off and install the new hanger with the supplied bolts.
You'll have to look at your current hangers to see how many bolt holes it currently has.
https://switchsuspension.com/lowering-parts/rear-drop-hangers/chevrolet/
https://switchsuspension.com/shop/lowering-suspension/lowering-parts/rear-drop-kits/chevrolet/silverado-2500hd-3500hd/
