On 8/15/2019 at 10:03 AM, coty52 said:
Theyre $120 from your dealer or $80 from gm parts direct. I ordered an extra set and sent them off for modeling for custom badges. I didnt even open the box though so i cant answer the original question
Do you have a part number?
  • 4 months later...
Here is what I ended up doing... the 6.2 V8 portion is on there with 2 sided tape. Got under it carefully with a razor blade and peeled it off. I traced the emblem onto some plexiglass, cut it out and sanded until it fit correctly. Next I painted it to match my truck for a subtle look. I didnt want a blank badge, so I added the 376 for something different.
  • 3 weeks later...
Is this what you were looking for?
https://airdesignusa.com/sierra-2019-fender-vents-set-of-2.html
I installed their functional fender vents  on my 2020 Silverado 1500.  It was a bit nerve racking cutting into the fender, but even for a grinder virgin like myself, it came out looking factory.  Even the wife couldn't tell I had done anything to the truck when I was done.
If you call in to place the order, ask for Marycruz and tell her Tobie sent you.  She's helped me out combining shipping charges for multiple piece orders.
Edited by R. Anthony Tobie
  • 5 months later...
  • 7 months later...
On 8/16/2019 at 9:51 AM, hd.brown77 said:
Sent from my SM-G955U using Tapatalk
How do you remove the entire badge and clips inside? Just pliers squeezing the plastic? No good tutorials yet.
thanks
