3 hours ago, Grumpy Bear said:
How many miles was that? Thanks in advance.
That photo was taken a really, really long time ago so I couldnt say exact mileage but it was only within 500miles of installing the can.You would be really surprised the large amounts of oil you can catch going into the engine if you wait until oil change intervals.
Edited by WHITESSTOWPIG
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
