chevrolet silverado 2016
Pop the hood and look over by the battery where the brain is for the power steps. Pull the in line fuse and reinsert. My amp power steps stopped working yesterday randomly. Never had any problems with them in over 3 years. I did this and they reset or something and work fine now.
i did this a couple of times and only once i heard something from the steps
Follow the wiring and look for rubbed spots if its not the fuse. If not a fuse or rubbed wire, then you have issues with whatever actuates the steps, or a relay/bad connector. No easy way for us to tell you how to fix it without knowing more. Seeing as how neither step is working, it probably isn't the actuator on the boards, rather a wiring issue or relay issue.
