Truck color change for 360 surround
Villain
Is there a way to change the color of the truck displayed on the screen? I have a black truck and it shows a silver truck. f5c0bbc8caae559cce2f9580a98d75c9.jpg
Nope, yet you can on a Lexus ES that costs less. But you couldn’t on my 17 Audi that cost 70k.
I think there is logical reasons they wouldn’t let you set it to a black truck. Everything would be black and you wouldn’t really be able to make heads or tails of anything on screen at a glance. Driving on blacktop, with a black truck, black windows, black bed. Some other vehicle colors would work, but I think I’m screwed either way!
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
