Oil presssure spike
Just changed the oil on my 2016 silverado 1500, after doing so, i noticed the oil pressure goes up to almost 80 psi when im hard on the pedal, not sure if this is normal and i just havent noticed before or if something is wrong
I used castrol 0w-20 full synthetic
2015+ GM SUV (Tahoe, Yukon, suburban, Yukon xl) have a 2 stage variable displacement oil pump as well.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
