Its that time again!
Jpshostr
Hope you enjoy!
I think this rig is toast.
A tad bit damp to being doing some scraper work.
Just need a bit more grunt, these 400 horsepower aren't enough!
A John Deere STS that decided to make popcorn in the field.
"I'm telling ya, she just dropped!"
You know its wet when you need a dozer to push your sweet corn harvest through the field.
Sure would be nice if those $350,000 combines would keep their wheels on.
Clark loader, going down.
Always a good idea to check lug nuts, especially on a $100,000 tractor.
Talk about one #### of a sinkhole, I think this Axial Flow sure found one.
The trailer just snapped.
We're enjoying pics of the demises of some rather expensive equipment? You bet we are! :thumbs:
Thanks JP.  :thumbs:
Yep, I love this pictures, always get a good laugh out of them.  Keep posting them when you get more good ones Jp.   :thumbs:
You say you want more?  OK.
Mud,  a sprayer with thin tires and an 850 gallon tank sprayer tank, and a Steiger wanting to pull it out.  I see bad things about to happen.
How a guy can roll a beet harvester on level ground with no mud in sight amazes me.
Always bad when you have to be dug out since they can't pull you out.
As Tim Allen would say, "Its BRITISH!!!!, and its stuck!!!!!"
Yes, there are wheels under that wagon.
Look whats coming out of the ground here!
Ah yes, everybody loves to see a piece of "heavy duty" equipment getting it's a$$ kicked so to speak...as long as we're not footing the bill and it's not our stupidity or poor assembly, etc. that got it there.
