Biggest tire
I know this has been talked about a lot but I’ll ask anyways. I have a 19 Silverado 2500 4x4 with after market 17x9 wheels with a +18 offset. I am close to needing new tires. I currently have the Tbars turned 5 full turns and am thinking about going 3-4 more full turns and then try and fit a 305/70R17 tire. Has anybody done this? Thanks.
The 19 2500 is the last generation body style, this forum is for the T1 trucks. I'm sure you'll get many answers over there.
