dvd double din
so I have a 2014 ltz with all the bells but I wanted to add apple car play, I know you can update the units from a newer Silverado, thing is I would have to spend around 600 just to update the factory radio aka finding both boxes getting them programed to the vin, new chargers. but I figure if I was gonna spend that much money why not throw a couple hundred more for a aftermarket radio and have better sound, I've always had aftermarket stereos in my cars and trucks and it always made better sound on the stock speakers and more options to customize, so I thing im concerted about is losing the factory options putting on heat or ac the seats when auto started or lighting or folding mirrors and so on, all the vehicle settings, I know they sell kits to plug in so you can still get the factory settings threw the steering wheel but I don't have those in the vehicle setting threw the small screen. so I guess im asking the people who have made the swap to a aftermarket stereo and what are the features you lose?
You mentioned a couple hundred more but a decent DVD player with navigation is a grand and then yes will need to have all the goodies changed out. You will need metra or pac modules to get back steering controls, on star, then you will need new m radio control, and if you want all the usbs to work the. Will have to splice into them. All of that is approx 1500 plus then you want better interior speakers bc most aftermarket decks will blow factory speakers. So min another 3-400 on the low end for new door speakers.
So just make sure what your gonna do look at the full cost and if you don’t do the add ons you can lose all the factory options.
Your right, I have been looking into this and found a nice kenwwod DVD player For around 700 and I’m not worried about Navi or onstar I don’t use, I use apple car play a lot and there Navi is way better and I’ve been looking on crutchfield they sell all the adapters for 300 and that’s to keep all the stock settings for the steering wheel, so yes about a 1000 for a new deck, when trying to upgrade a stock deck for 650 and it’s still stock, so I guess I’m a little confused on the factory car settings you get with the stock deck like auto start setting and auto lock and so on basically the truck settings. You don’t get those setting threw the steering wheel controls
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
