Where did R& D go ??
I want to find the kit that defeats the auto-on headlamps on my '99 Silverado. I did a search and found that R & D has a kit, but the link to the website only displays a "Forbidden to Access" message.
Are they still in business?? Or did they simply change their website URL??
R & D had some great products. I had them on my 2001 Tahoe and on my 2001 Silverado. When I got rid of the 2001 Silverado for a 2003 model, I wanted the same headlight and foglight controllers, but discovered through this site that there were wiring differences between the model years and they wouldn't work. I have tried countless emails and online inquiries for additional information, like many others I have seen posting on this site, to no avail. Maybe it's just as well they aren't in business if they can't reply to anyone.
Eric
you could just unplug the bulbs and save some $$$ :jester:
Then you would have no headlights at night.. I think he would kind of need those... I am in the same boat looking for something to disable the auto head light BS. I cant believe GM did something like that.. but oh well i love my truck anyway
For those with '99 and early model '00's, you can replace the Body Control Module (BCM) with one from a newer model (2001 and up, to be safe) truck or new body style SUV, and then you will have the ability to press the dome override button a series of times to disable the auto headlights. It's not permanent, you'll have to do it everytime you re-start you truck. I've seen them go on e-bay for around $20.
Plus, you'll gain the ability to program your door locks to operate in a few different ways.
I have several of the R&D items, and have not had any problems with them. Too bad they don't seem to respond to people any more.
Good luck.
I thought he was talkin about the DRLs. He could just use the parkin brake trick on the rare occasion he wanted the lights off when it was dark.
GUYS.........Check out http://www.lightsout.org
Free info. to shut off DRLs and auto ons.......
BTW:
Somebody else had a easy fix to shut off DRLs and auto
ons Posted here recently !
D**N ! I have the print out here but the email addy is
cut off!............
Try this.. http://home.mensicom/~d.lang/Auto_Headligh...hts_Disable.htm
.... hope it works!.....geo
EDIT: BUMMER..NO good,,,,.....Anybody got it?
BTW:
Hey sonjab is this what you are talking about. I have not done this but got this from anther site.
"I just found this forum today and saw some old questions that have not been answered, so I thought I would help some of you out.
Listed below are the instructions that I came up with about a year ago to disable the auto headlights on the 1999 Silverado/Sierra new body style trucks. I have had
mine like this for nearly a year and it works great. There is a little work involved, but it sure beats
paying $90 for the little pushbutton gadget from R&D Truck Acc., (no offense Darrell). Keep in mind that I am talking about the automatic headlights (twilight sentinel) and NOT the d**n DRL's!!!
Yes, I already know there is a fuse for the DRL's under the hood or you can just pull the bulbs out. Good luck and let me know if you
need any help. Later,
For those that don't know, the twilight sentinel is the feature that automatically turns on the
headlights and taillights when it starts to get dark outside. I like this feature alot, but I
wanted to find a way to disable it when hunting season comes around. I also like to use just
the amber colored running lights in certain situations. These instructions are for my new body
style '99 Silverado regular-cab, with LS option package.
There are two ways that you can do this procedure. The first one I have listed is how I did it
the first time not long after I bought my truck. The second way I have listed is how I did it a
few weeks ago just to see which way would be easier. I personally like the second way better,
but read both ways that way you will know everything that needs to be done.
Things needed are: One 1.5K ohm 1/2 watt resistor (Radio Shack, $0.49 for a package of 5),
electrical tape, pliers, and having small hands is a plus. A small socket set with ratchets &
screwdrivers will come in handy too. Another nice tool to have is a dental pick. It makes
unplugging the connectors a lot easier.
Here is the first way:
#1. First thing to do is to pull off the face of the dash and get it out of the way. It just pulls
right off and snaps back on, no screws, bolts, or anything like that. It helps to lower the
steering wheel all the way down and if you have an automatic, put the shifter all the way down
into 1st. Be sure to set the parking brake, just in case! Next, pull out the radio, (push down
on the two black tabs that are kind of sticking out on each side & pull the radio towards you at
the same time), and unplug the connector and antennae and set it out of the way. You should
be able to see the bottom of the ambient light sensor that is near the front of the dash,(it has
one gray wire and one white wire running to it). Try to twist the sensor to unscrew it from the
dash, (I had to use pliers from the top side on mine). Once loose, pull the sensor down from
the hole in the dash,(it can not be pulled through the top), unplug it from the the connector,
(not easy), and remove. Don't drop it or it might be lost forever down in the dash
somewhere. Now take the connector plug-in (the one with the gray & white wire) and route it
up through the hole in the middle of the dash for easier access to it. Now you can plug in the
resistor into the connector, (I found that it works best to fold the wires of the resistor over
itself once to be sure that the wires are making contact to the connector), and tape it up with
electrical tape. Be sure to test it out to make d**n sure that it works, (hint: Release the
parking brake or else you won’t know if it is working correctly.). If it is not installed
correctly, the headlights & taillights will come on whenever the truck is turned on, day or
night. What you do next is up to you. You can either re-install the unplugged light sensor to
fill in the hole in the dash or leave it out and have a hole in the dash. Put the radio and dash
back in and your done!
I've had mine wired this way for months and have had no problems at all, it doesn't get hot or
anything and I have total control of the headlights.
The second way to do this is…….
#2. Another way to do this is to remove the whole upper dash unit. It really wasn't that hard
to do and it makes it ALOT easier to get to the ambient light sensor. You do not have to
remove the radio if you do it this way.
First thing I did was remove the face plate cover that covers the radio, gauges, etc. Then
removed the 5 nut screws that hold the dash cover to the instrument panel. Took out the
screws that are on each side of dash, (in the door jam areas, covered by the fuse panels).
Removed the plastic A-pillar covers, (they just pop out from the top, be sure to put the metal
clips back on the cover before re-installation). Got a butter knife and popped out the 2 A/C
vents on the passenger side and removed the 2 screws that are in the holes there. Pulled out
the "handle" that is directly above the passenger side airbag, (if you look inside the A/C vent
holes you will see a white plastic "clip" on each side that is holding the steel rods of the
handle, push these in slightly and pull the whole handle out). Double-check for any screws or
clips, just in case I forgot to mention some.
Now the hard part. You have to pull hard, straight back on the dash cover to get it out. I
started on the driver side and worked my way to the passenger side. I put one hand between
the bottom of the windshield and the front part of the dash in the driver side corner between
the windshield & bottom of the A-pillar and pulled it straight back to "unclip" it from the
metal that is holding it there. You have to use a little force to get it out, but you will hear and
feel it pop when it gets out of the first clip. There are 5 or 6 of the clips that the front part of
the dash needs to be “unclipped” from. There are also 3 small clips that hold the dash to the
top part of the passenger side airbag cover, they don't take much force to be popped out. The
airbag stays in place. Don't pull too hard or something might break that you don't want to
break. After you unclipped all of them, you can pull the dash back a few inches and flip it up a
little bit to get to the light sensor and unscrew it from the hole, (twist it a 1/4 turn). Then you
can take the whole dash completely out of the truck.
Unplug the light sensor from the connector with the white & gray wires. Put in the resistor,
tape it up, test it out and put everything back in the way it came out. Putting the dash back in
can be a little tricky. Make sure everything is lined up right and pop it back into place. Put
all the screws back in and snap everything else back on and your done!
I wish I would have done it this way the first time, it is alot easier than fighting under the dash
trying to unplug that d**n sensor. You don't even have to take the radio out! I didn't break
anything while doing this and I was kind of rough with it at first because I wasn't sure how to
pull the dash out. It took me a little over an hour to do this, but I could probably do it in 15
minutes now that I know what to do.
Some truck owners have had to use different kinds of resistors, (different amperages,
wattages, Ohms, etc.), to be able to disable the auto headlights. Most owners, including
myself, have had the best luck with the resistor mentioned previously.
Some folks have added a toggle switch, or something similar, to the wires of the light sensor.
This way they can choose between having the auto headlights operational or have manual
control over them. I have not done this yet, but I will include some instructions of how I was
told to do this. These instruction were given to me by Chris Leigh, (Thanks Chris!). Here
they are:
“Neil,
Just get whatever type of two wire switch pleases you. Anything from the auto parts store will
do, if they don't have anything you like try a Radio Shack. Hook the resistor to the one of the
contacts on the switch, hook the other side of the switch to either of the sensor wires (white
or grey). [important note: If you solder rather than crimp connect be sure to use some type of
heat sink so that all the heat from soldering doesn't go into the resistor.] When the switch is
closed it'll work as it does now (manual mode). Open the switch and it should go into auto
mode. Mine was a little different (I have a 99 Silverado 2500) in that mine required two
resistors to allow for manul light operation and therefore the switch setup was a tiny bit
different. What I laid out for you is the setup for a 'one resistor bypass'. Mine has a bit of a
delay from the time you change the switch position to when the lights actually change mode. I
think this is something they build into the light relay to avoid inappropriate on-off action by
the lights……Chris”
Good luck & feel free to ask questions. Print this out so it is handy. My Email address is:
[email protected]
Later,
Neil
p.s. I might as well tell yall how to disable the DRL’s (Daytime Running Lights) too, because
I just know someone is going to ask.
There is a fuse for them in the “Electrical Center” that is under the hood on the drivers side.
It is a small, blue 10 amp fuse. Look under the lid to the electrical center and it will show
which fuse is the DRL fuse. Pulling this fuse does not affect any other accessories."
The BCM's in '99 and some '00's are not programmed to do that. It also doesn't give you an option to program the door locks yourself, you have to take it to the dealer, and then I don't believe you get as many ways to program them as teh newer trucks.
TOM.....Have forgotton where that disable link came from.
But NO pulling apart the dash on this fix !
So here is the instructions for 99-02 GM fullsizers!
Wish I had my scanner !
Basically you will need a pair of wire cutters and a 1.5k ohm 1/2 watt resistor
that you can get at radio shack. Elect. tape and poss. wire nuts will work to
wire in the resistor. You can solder the wires if you wish.
You will want to disconnect the neg. batt. cable.
First locate the Body Control Module (BCM) which is under the dash, below the
steering column. Laying on the floor, this should be visible without removing the dash panels. You should find a purple connector (C3). Unplug it.
Locate the white and gray wires (A4 and A6). I don't remember if the white is
A4 and gray is A6 or vise versa. It doesn't matter anyway.
Clip these 2 wires that are coming off this plug (C3). Leave a few inches to work
with. Tape up or place wire nuts over the other end of these wires that go up and under the dash (they go to the light sensor).
You now have removed the light sensor from the electrical system and it is now
a dash ornament.
Connect the gray wire from the plug (C3) to one end of the resistor and the
white wire to the other end. Make sure you tape upall the wires to prevent a
short. You should now have a gray wire coming from (C3), going to one lead of the resistor and the white wire from (C3) to the other resistor lead.
Plug in the C-3 to the BCM and replace the neg. battery cable.
Start the truck and make sure the lights are off. Throw a dark towel over the light sensor on the dash to verify the lights stay off.
Try your light switch and if they work you have done it correctly and that it !
Shouldn't take very long after you find the wires which are right in front of you.
Much easier than taking apart the entire dash !!!!!!!!.................geo
BTW: GUYS just used this procedure to disable my buds 99
GM. Fast and easy too. NO tearing up the dash either !
I know it works !
Much easier than the fix listed below:
My 01 i used instructions off http://www.lightsout.org and rewired my
headlight switch. Ok but a PIA to do......................geo
Also cheaper than that R&D switch too !
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   6 Members, 0 Anonymous, 651 Guests (See full list)
