Trying to decide on what’s nexts
Tbone10
Hello all,
I recently joined the forum! I have a 2017 Sierra Denali and am trying to figure out my next move suspension wise. I currently am running a 2” rough country level with 33” ridge grapplers. I have had some frustration with the magneride system as suspension options are very limited below 6” inch lifts. My previous truck was 5.5” on 35s and I am looking for something that is not quite that high as I am using this truck for more daily driver responsibilities and want it to ride as smooth as possible. Ideally I am looking for a 3.5” look but magneride does not offer a lift of that size. My 2” level rides great but I am looking for just a little more height especially on the front wheel well without compromising too much ride quality. I would appreciate any feedback or suggestions!
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
