How to keep USB and Cig sockets live when key off 2018 Yukon?
CtSeaRay
Hey Guys,
has anyone figured out how to keep the USB and Cig assy sockets live when the key is off? Thanks in advance, this is driving me nuts!
  • 3 weeks later...
I don't think you can do it with the USB ports, but you can make the forward, center power port hot by moving a fuse in the panel by the driver's door.  I found that somewhere here a while back, will have to search for the link but you may also check your owners manual.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
