Location of brake control module
Mdsjohna
Hello I did a quick google search and didn’t find anything.
I took my 14 Silverado in for a few things today. One of which was the brake control module recall.
When I dropped it off this morning my aftermarket stereo worked and when I picked it up it didn’t. Total blank screen no power. Of course hopefully it’s just a fuse
Say that the only remotely probable cause was this recall. Like if I find out the module is behind the stereo it seems we are on the right track. Unfortunately I don’t know where it is. Of course it could be just really bad luck but I doubt it.
Thanks in advance.
The reprogram is done thru the OBD2 port, the BCM is under the dash somewhere I believe.
The most common use of BCM is body control module, which typically is under the dash in GM's trucks.
Don't know where a "brake control module" would be, in my truck the ABS controller is under the cab, beneath the driver's seat.
Anyway the dealer did something to cause it but I disconnected the negative battery terminal and reseated some fuses and it seems to work now.
