Too high tech
17 hours ago, j-ten-ner said:
Proper driver education is the key. Not technology. Technology is only an aid for the educated (and skilled) driver.
So... education helps the driver, and technology helps the educated driver.
So, right then.  Both are good.  Let's have both.
-Daver
  • Replies 46
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
