2019 at4 wheels on a 2018
I have a 2018 SLT. It has those ridiculous chrome clad wheels on it and they have recently been destroyed thanks to a curb and some icy roads. The only wheels for sale locally are some at4 20 inch wheels But they come with a 33 inch tire
Does anybody know if I would have fitment issues
I know that model truck comes with a 2 1/2 inch lift so I’m inclined to pass on these.
That being said if anybody has a set of 20 inch rims for sale and you’re in the Northeast let me know
You can put 2019+ T1 rims on a K2. You can not put K2 rims on a T1 due to the larger brake caliper. You will be good to go. It is still the 139.7 x 6 bolt pattern with a 78.1 centre bore.
What about the tire size? 275X60R-20s
Would those work on a stock truck without issue?  I tow a bit and would hate to have rubbing issues.
The 275/60R20 is a 33" tire, your stock size is 275/55R20 which is a 32" tire right? I am not fully certain, but I am fairly confident that additional 1" of overall height will not cause any clearance issues in a stock ride height truck with no level most of the rubbing comes from excessively over width tires. You definitely wont have an issue on the rear where you will squat while towing. Worse case you might touch the mudflap or wheel liner at full lock in the front with your trailer on. You can always sell the tires for a good dollar and swap yours over if it was just the wheels that were damaged.
I think with stock rims you may have slight rubbing on the fender liner. You should be able to solve that by zip tying the liner from behind.
I went ahead and backed out.   I didn't want to deal with an alignment and all that.  I just need rims :(
Beautiful set of wheels though.
Thanks for the information.
Could try to replace yours, I would assume all 4 aren't screwed. But you did mention you disliked them. Here is a shot anyway if your interested in finding OEM replacements. Lots of Chinese companies making knock offs too. https://www.originalwheels.com/gmc-wheels/sierra1500rims.php
https://stockwheelsolutions.com/search.php?search_query=Sierra&section=product
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 488 Guests (See full list)
