Rattle in 5.3 engine at cold start up
Since recently buying a 2016 Sierra 1500 with a 5.3 engine I have discovered a couple of unusual sounds in this engine that I am not used to hearing but according to the folks here they are not out of the ordinary. I have been hearing one other sound though that I want to ask y'all about and that is when it is started after sitting all night. For  a split second there is a sound that seems to me to be the sound of main bearings rattling and then it goes away quickly. This truck has 42,000 miles on it and has been meticulously maintained so I wouldn't think it is the mains but am wondering if others here have the same type sound in your engines. Thank you for your input. I have only owned diesel pickups for years so am having to get used to this gas burner.
d
I hear mine every cool morning. Noise started around 15,000 miles and I am at 242000 miles now.  I brought it in several times while it was under warranty, told me its normal.  I worried about it but it's never been a problem other than the lifters clacking until enough oil gets going.
Most likely lifter noise.
I had the piston slap noise on my 01  Silverado that everyone was freaking out about back in the day and stopped it by going to a heavier oil.
Switching from 5-30 to 10-30 stopped it as the heavier oil clings to the parts for a longer period of time.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
