CMP (Cam Sensor) Scan tool reading
Does anyone know what the correct reading I should see for my CMP high-low and CMP Low-High on my OTC Scanner.  I'm not getting a code but trying to see if my cam sensor is out of sync with the Crank sensor causing a missfire on #1 and #6 cylinders.  I've tried to do a crank relearn but I get a fail code from my scanner.  So I'm trying to see if something is not right with the correlation between the two sensors.  Truck has 160,000 miles on it.
Get a subscription to the shop manual for your truck at AllDataDIY.  There should be a menu reading to see if it is out of sync I think.
I have a shop manual and all it says for the numbers the scanner reads is they vary no range given.  Maybe someone could read their truck and tell me what numbers they have.
