Torque value for 2013 cylinder head
It might also have a pattern to torque the head down as well...  And might have torque-to-yield bolts (as in, single-use bolts) [I don't know one way or the other, but you want to find out before doing it].
  • txab changed the title to Torque value for 2013 cylinder head
On 11/10/2019 at 8:42 AM, Spud Perona said:
Thanks but that was all i found so far(pattern & single use bolts)I'm just wondering if its the same as most gms
Are you using stock head bolts of ARP? Here is the stock head bolt torque specs https://help.summitracing.com/app/answers/detail/a_id/5187/~/how-do-i-install-my-ls-cylinder-heads%3F
Cylinder Head M8 Bolts - in Sequence    30 Nm (22 lb ft)
Cylinder Head M11 Bolts - First Pass in Sequence    30 Nm (22 lb ft)
Cylinder Head M11 Bolts - Second Pass in Sequence    90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence    70 degrees
TTY Bolts
Double check with Summit.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 464 Guests (See full list)
