Tahoe got some lovin' this weekend
Spent some hours on the tahoe this weekend..
Changed the Fuel filter...Cake, but I thought I would release enough pressure off the line by pulling the fuel punp fuse, and running it. Not so much, fuel came ouyt like a fire house when i un-bolted it! Otherwise, easy fix
Changed plugs. Sucks trying to remove those wires!!! Ended up replacing the wires too :cheers: ! That pass side rear plugh was a BLAST!!
Cleaned MAFS, simple, easy, straight forward.
Replaced Intermediate steering shaft. In hope to reduce the clunk! Simple, straight forard fix also. So far so good!
Put in a bottle of Fuel Injector cleaner... (upen gas cap, pour in...talk about simple!! :cheers: )
Ran a can of Combustion Chanber cleaner... Pulled off the hose at intake, spray in while engine is running....Turn off engine when can is empty,,,,let sit 20 min or so. Start up engine, and fog the neighborhood for skeeters! :cheers:
Over all I think I gained a little performance. But mostly a smoother idle, and just a smoother running engine. Hope this stuff may eliminate some pinging too! well see!
Now I just need to put new brake pads on front; fix rear e-brake pads; give it a good wash / wax; rotate tires....Guess thats next weekend!!
Thanks all for the help and knowledge on some of the things I did today!!
Mike
Spent lots of quality time with mine as well. Needed to fix exhaust leak caused by broken back bolt on DS exhaust manifold. Six hours Sat and five more Sun to get it done. You have to remove PS pulley to get the pump off. I'd like to kick the designer of that set up in the nuts. Put in new plugs as well. Runs good and no ticking anymore. d**n my hands are sore today. Mike
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
