03 suburban blow motor
So today Yesterday I was driving and I smelled a burning wire smell. Thought maybe it was just sucking it in from outside. Today same thing but after I went to an appointment and came back out after an hr or so I had no front blower motor. Got home tested the motor it was fine. Spun on 12v. Pulled the resistor and noticed that it has melted around the black wire. I replaced the resistor and the connector to it. I still don’t have any blower motor on any speeds same as before. Any ideas would be a huge help as it’s arctic cold here in Michigan and the rear heat only warms this thing up so good.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
