2015 complete loss of power steering
Ross98
Could use some help here, after going down some trails in my 2015 Silverado z71 I had an accident and my right front wheel hit a tree as the wheels stick out a little bit after that my power steering went out and my “service stabilitrack” light came on and another message that says “power steering reduced” Put my own code reader on it said low circuit for both front wheel speed sensors and there was a code for the steering angle sensor.
You probably knocked your wheel out of alignment, or broke the sensors/wire off the hub. Take it in and have it aligned/replace what ever you bent when you hit the tree. Probably just a tie rod end.
