Check Engine Light
mistermcgoo
I just installed a pedal commander and unfortunately it ended up dropping my truck into low power mode and the check engine light came on last night. Which is a common issue with pedal commanders from what I understand..
I just unplugged it, plugged the OEM throttle harness wiring back in and restarted the truck, which solved the low power mode issue. However, the check engine light remained on. So I went ahead and ordered a OBD II scan tool to clear the error code. Funny thing is though, I went and started my truck this morning the check engine light was gone.
 I was under the impression that the only way to turn the check engine light off and clear the code is to use a scan tool? Can warning lights clear themselves?
Nope, while error codes will remain as "history codes", so you can read them later with a scan tool, the computers will keep checking, and if the problem is fixed/no longer happens, the code stops being current, and if it also resulted in the CEL being turned on, the CEL will go off.
Depending on what the problem was, how quickly the light will go off after fixing the problem will vary, sometimes right away (if say, you left the MAF sensor unplugged and you plugged it back in), sometimes it will take a number of ignition cycles to go away, or sometimes it takes a specific set of driving conditions to re-run the test and then the light will go away.
Also, you're vehicle will generate codes without turning on the CEL, if the problem is not emissions-related, so it's a good idea to periodically scan for codes.  And the basic code readers will only read codes from the ECM, or perhaps a couple others (commonly the TCM, ABS and/or SRS[air bags] computers), but there's 10+ more in your truck...
I wouldn't sweat it, that stored history probably won't affect your power train warranty.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
