Just an FYI for everyone to get their trucks to the dealer to get this done, I don't know about my friends south of the border but it's fully winter here and I miss my rear defrost. Also note that the recall # and repair may differ for anyone in the States as this applies Canadian trucks only.
Mods, feel free to Sticky this if you feel it warrants that.
GM Program #:
N192270330
Date Issued:
Nov 08, 2019
Program Title:
Rear Window Defroster Thermal Events
Program Description:
Certain 2014-2019 model year Chevrolet Silverado and GMC Sierra vehicles equipped with a power sliding rear window (RPO A48) had safety recall #N192220470 performed. This field action restores the rear window defrost function.
Repair Description:
Dealers will replace the buss bar covers and the contact cover, and for certain vehicles, will reprogram the HVAC calibration to disable the rear defroster from automatically turning on at keyed start. Please note that the rear defroster will automatically turn on during remote start or by pushing the manual button and is not affected by this calibration. If the rear window or sliding glass assembly appears damaged due to an occurrence of high electrical resistance on the rear defroster circuit, they will also be replaced. Dealers will also install the rear defroster fuse that was previously removed in field action # N192220470.
Sent from my Samsung using Tapatalk
Have you had the work done?  Mine melted the plastic cover on the fingers that contact the outside window frame to give power to the center glass defrost circuit.  I tried soldering it back on and I don't know what solder they used but nothing I tried would stick.  It actually blew one set of the fingers off and took the plastic cover with it when it failed lol.  The fingers are all blued so they were not making good contact.  Truthfully I like to drive with the rear glass just cracked open  so that probably contributed to it although I never turn the defroster on... truck does that on it's own and I can't disable it for remote starts.  You can see the cover I mean in the bottom right hand corner of the middle glass.
I'm curious what their repairs look like lol.  I'm fine with mine never working again as I do not use my rear window to look out of but if it's not a total butcher job I may go get the recall completed.
Edited by SierraHD17
No I have not had the work done yet. Do you have pictures of your rear window? I'd love to see the carnage lol
I can grab one tonight haha.  I glued the melted back cover back on to hide the exposed contacts as this happened before the recall existed.  I will probably pop it back off again.
Finally. I've been waiting for this. Never had it disabled since I may have opened the rear window once. I'll take a defrosting window over a sliding window any day.
The piece that melted the cover and shot across the cab with the cover.  Yes I glued the cover back on and pulled the 30 amp defrost fuse.
Holy! I can't believe they actually had the potential of exploding.
Anyone have this work done, I just got the recall done and the work order says 1 22917202 25300 fuse, 1 84819605 164640 window, 1 84819606 164640 window.  Performed recall, replaced rear bus bar covers, terminal covers and fues. Verified heat damage not present.  HVAC programming not applicable.
The issue is that it rained like crazy last night and this morning my entire headliner along the back window from side to side was completely soaked.
How long did this service take?
Has anyone had the rear glass shatter after having the recall completed? I have a 2017 2500 that had the recall completed in July 2020 and the rear glass just shattered. The dealer says it's not covered under the recall.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
