LT to LTZ seat swap
White2015
Has anyone swapped the LT2 heated split bench front and rear seats out with the leather from and LTZ model? Was thinking about looking for some in local junk yards from “totaled” trucks. Didn’t know if it would be possible or not.
Here’s a couple threads to get you started there’s at least 10 more on here about this. The answer is YES, but... also assuming you’re wanting to go from the bench  to buckets and the console? otherwise if not Katzkins is the way to go IMO if your are happy with your current seats and are only wanting leather.
This thread is for the center console upgrade
If you just want leather get some Katzkins. They look factory. They are $550 on eBay.
Here's one of my trucks I did the Katzkins on.
How difficult was the install? I have been thinking about this for awhile. I just don’t want to pay the grand to have them installed. Ty.
I payed an upholstery shop to do both my trucks.
Premier Upholstery Rogers Mn
Labor was $450 for each truck. $1000 total for each truck.
I was going to try it myself but decided I want it done right .
Here's my DBL cab.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 458 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
