Frame strength after lift?
I've been sort of wondering about what actually happens to the frame on an IFS (88-present) truck when you lift it ...
Most (if not all) kits that I've seen require cutting out a portion of the frame in order to install the subframe crossmembers ....
Any time you cut a peice of hardened, heat treated steel like the frame of a vehicle is, you inherently weaken it.
While most of the time when you weld something in place, the weld winds up being stronger than the rest of the section ....
I guess my question is, have any of you ever noticed anyone with a lifted truck having cracks around that portion of the frame where the new subframe crossmembers were welded in place?
I figure that some of you with older trucks may have had your lifts on for quite a few many miles .... How has the frame of the truck, as well as the lift, held up to extended usage?
Any input on this would be cool. thanks....
My blazer that had about 125k when I put my lift on it, now it has about 186k with nothing broken yet. I've done just about everything I have ever wanted to do to it, with a broken part...(knock on wood)...but that wasn't IFS. as far as my 2500 goes, the only thing that broke on it was a CV joint, and I don't blame that on the lift, I blame that on the installer.
as far as the frame goes...so far the only thing I have done to it is sprayed some of the coating back on, because it came off in places where they worked on it.
You've never cracked the frame at the steering box?
In the early 90's, me and about 4 of my friends all had different style Chevy trucks but they were all between the 81-87 years. They ranged from 3" bodylift w/33" tires to 12" suspension lift w/40" tires. Every single one of us had to weld up cracks in the frame.
It's not that I think your lying, but have you check the frame there lately? If it's not, then your one of the few. Especially on a K5 that has a slightly thinner frame the the pickups in those years.
No..I know about that problem, never happened....and it's not that i've been a **** with it either, I've gotten air with the biatch on the beach before. It's just never happened. The largest tires I have ever run with it are 36x14.5's so maybe that has something to do with it? or maybe it's just dumb luck?
tmf
I can't speak with certainty for anything but the Superlift for my truck, but I doubt that other lift kits (Rancho, RCD, ProComp, CST, etc.) are substantially different.
I installed the Superlift on my truck, so I know what I had to cut in order to attach the lift bracketry.
When installing the lift, some cutting is required, however what is cut away is not any of the length of the frame, but rather the tabs for the factory driver side lower differential bracket, the extension travel stop, and part of the upper control arm bracket. This information is on page 7 of my installation manual (form 3290.01-05010).
There is no cutting of material from the length of the frame, nor is there any cutting of frame members that run from side to side, connecting the frame rails.
I do not believe that there is any compromise in frame strength resulting from the installation of the lift, however, I do believe that it would be a challenge at best to remove the lift from the truck, restore it to stock, and have it look like stock. To do this, you would have to weld material onto the frame.
If you have any questions on concerns about it, try calling Superlift (or the lift manufacturer of your choice), tell them you have a pre-sales technical support question, and then ask away. My experience with their technical support has been that they are helpfull and courteous.
If you'd like, I can take pictures of the frame and suspension as it looks with the lift installed so you can see (or not see) what has been removed.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
