Sierra speedometer not accurate
I have a gmc sierra 2014 single cab, recently i have replaced my gauge cluster running 265s r18 but after replacing my cluster i have noticed difference in gauge speed vs actual gps speed
gauge speed giving 125km/h and actual speed 129km/h, the car is performance custom tuned, how can i calibrate the speed without affecting the custom tune? Anyone with knowledge can help me with this?
You can have the speedometer recalibrated at your local GM dealer. They should be able to do it without changing the tune, but if they cant you will have to contact your tuner to do it for you.
My dealer wanted 500.00 CAD to recalibrate my speedometer. They told me 300.00 for a part they had to order and 150.00 to do it (plus taxes). I went on-line and ordered the part myself and am currently waiting for it.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 836 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
