2009 gmc sierra 1500 sle
i have a 2009 gmc sierra 1500 sle i have the rpo code AP8 is this the code for remote start (right) my fob only has lock and unlock if i purchase a fob with remote start do i just programm it to my truck or do i have to get it programmed by a gm tech
RPO AP8 is a "Remote Starter Prep Package," meaning the car is wired for remote start, but it isn't enabled. Enabling it means purchasing a kit (2 fobs, instructions, and a unique code) from GM. The dealer tech then calls the TechLink Center w/ the code and VIN to get a VCI to reprogram your BCM.Jun 1, 2009
