Hi Everyone
I have a 2014 Silverado with an intermittent heating issue.   The fan turns off and on for no reason.  It does this if I have it on auto and all other settings.  When it happens I turn the system off and on and fiddle between settings which may or may not resolve.  It usually won't stay off for more than 30 seconds and turns back on....but once it starts acting up it goes off and on and is very annoying.  It only does this once the truck is warm and after driving for 20 minutes or so.  Had no issue during the summer with A/C etc.
Thx
The next time it happens, pull safely off of the road, turn off the engine, remove key, and open drivers door.
Sit for a couple of minutes, then start the truck again and see what happens.
That will usually reset most things that have become "confused" and need to be reset.
Can always disconnect battery for 30 minutes, and then hook it back up.
  • 4 years later...
12 hours ago, Grimaries said:
Ever figure out the issue? I’m dealing with the exact same issue you described
Our team regrets to hear of this HVAC concern that you have been experiencing and we would like to take the time to learn more and assist. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to hearing from you.
  • Haha 1
Has you or your team been actually able to assist anyone. It's kind of ignorant to make a post and not follow up with any info for a solution. Your account is pretty much a joke. I look forward to hearing from you...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
