Problem with cat converter???
RBSilvy85
I noticed last week I am getting a faint rotten egg smell from my truck exhaust. I had a cat go bad on my 03 Silverado but it was completely plugged and woukd mot accelerate. Is the rotten egg smell definitely a sign a cat is failing? I haven't noticed any other symptoms nor do I have any codes. I have 65k on my 2015 should I take it in to dealership while its still under the 80k federal warranty or should I jist let it ride for now?
That sounds like a failing cat to me. I'd take it in or at least talk to them. I just took mine in today for a p420 code which is supposed to be a failed cat but the truck seems fine, no smells. We'll see what they say.
Sent from my SM-G892A using Tapatalk
Yeah, that's what I was thinking. Curious to see what they say about yours. Please keep me updated if you could.
I was told this afternoon that the converter has failed and will be replaced. There looks to be three on the diagram. I'm not sure if they mean all three or just one of them.
It's going to be covered under the 80k emissions warranty. I got in just under the wire, thankfully. The truck has 78,500 miles.
Got the truck back yesterday. They said the screen and core of at least one cat we're loose and rattling. It was covered by the 8y/80kmile emissions warranty.
I was told it'd be about a $2000 job (at the dealer) had I been past the warranty period. I had 78,500+ when I rolled in.
The truck seems fine and the mysterious exhaust rattle that appeared after my AFM repair is gone. I thought it was a heat shield, but turned out to be this.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 695 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
