I’m having a issue with the dashboard not coming on not working what so ever . Speedo and rpm gauge not working and the digital display not showing up and also my radio blacked out as well plus steering wheels controls are not lit up . But everything else seems to work fine . Even my backup camera comes on in reverse it’s very odd to me so if anyone could help I’d appreciate it deeply .
Welcome to the site.
My guess is your HMI module is going bad. Taking down one function at a time.
So it that will cause all that stuff to not work. Or that just for the radio? I just wondering if it’s a fuse or something .
Believe it controls most/all of the electronics associated with the dash.
There are some post on here about the same/similar problem.
  • Thanks 1
Could lead me in the right direction cause I really shouldn’t be driving it until it fixed and I’d like to do what I need cause I have no idea what’s going on and I just got the truck about a week ago and haven’t even drove it but once . And I appreciate your help
22 minutes ago, 15 denali said:
And it that the box that you remove the glove box to get to with like 5 plugs or something .
Yes sir.
I would do some research and see if you can upgrade to the current version so you can add CarPlay, if that is really the problem.
4 minutes ago, JimCost2014 said:
Yes sir.
Ok cool I really appreciate the help . I’ll run through everything one more time tomorrow and see what I come up with . And also to know if it’s bad would I need to take it to the dealership to let them run a test to determine if that the issues if I can’t fine anything myself.
You are very welcome.
Good luck!
Good luck!
Well I have figured out the issue I’m sure I put in some aftermarket leds headlights bulbs and well I decided to remove them just to see and put the factory yellow bulbs back in and got up this morning and opened the dirt everything is working completely fine . That’s just crazy . So now I have to do some research and get some actual led bulbs that won’t effect that problem from happening again .
That is good news for the holiday's.
Search around on the site to find a brand of LED's that don't cause adverse electrical effects and you should be fine to run them.
Merry Christmas!!!
Merry Christmas!!!
Yeah it was great news and will do! Thank you and marry Christmas to you as well!
Well here I am again it work for like 2 days then back to not working again . I ordered a hmi and just replaced it and still nothing I’ve checked all my fuses and none are blown. Help please .
Post a picture of your dash, so we can see what you are describing.
Do any of the lights on the gauge cluster work?
    Markey
    Markey
  • Who's Online   4 Members, 0 Anonymous, 1,603 Guests (See full list)
