Occasional No Brakes at Low Speeds
I have a 2002 Silverado and within the last year or so occasionally when you are coming to a complete stop, the brakes go to the floor and make a wining noise for the last 10 or so feet.  The truck is hardly driven the last couple of years but the brake lines and pads have been replaced within the last few years.  The master cylinder has fluid in the reserve tank.  Anyone deal with something similar?
You might consider flushing both the power steering fluid (this is also used by the Hydroboost to assist in braking) and the brake fluid (it attracts water from the air and doesn't perform as well).
Sounds exactly like a wheel speed sensor dropping out as you slow down.
I've run into this issue many times before. If I was watching each wheel on a scan tool, in this case both front wheels, one of the sensors would drop out to zero mph as the vehicle is coming to a stop. It can cause the pedal to become really soft and the whining is the ABS pump.
If possible, get the truck hooked up to a nice scan tool that can do live data readings for each wheel and see if you can watch them as you start slowing down.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
