Yes yes ive looked before anyone comes at me.
Im not a member yet bit i do need help.
My yruck is a 2012 Sierra Denali 1500. It has 140k miles and ive noticed that only from a dead stop when i push the gas it clunks. It also feels like there is a delay to when the front wheels catch. Im not sure what it is and any suggestions would be appreciated.
Thank you
You mean release,not catch? probably got to inspect brake pads for binding,a little sanding on pads and pad slide area,a touch of antiseize
First off, welcome to the club. We are mostly adults and understand the search function sucks. But if you need someone to get upset at you, head on over to GMfullsize.
This can be caused from a couple of different things but is prolly a combination of a group of things wearing out.
If the upper and lower ball joints are failing you will get this feeling as everything is shifting position prior to the wheels starting to roll. Ball joints are common on this year of GM truck and are easily serviceable. It is my recommendation to always replace tie rods when doing this as you will almost always need them done shortly after and you will save on labor to replace them now.
Could also be the brakes or other suspension related issue. The sway bar end links just about fall apart when they left the showroom floor.
If you can, get the front end off the ground and us a pry bar to move everything around. Lift up on the tires, wiggle back and fourth and side to side. If you can get it to pop you can locate the noise.
Another option is to stand outside and listen while someone operates the unit and see if you can here the noise a bit closer.
Your username cracked me up and indicates that once you fix the issue you wont return, but I hope to here back with the diagnosis.
Edited by Mikebtte
Thank you mikebtte and jetmek.
Im going to look it all over this weekend and whatever i find ill let you know.
Oh no. Don't you worry. I will be back with a thousand more questions and my username will stay exactly the same.
Thank you again for all the help. Will report back in a few days.
So i went through what i could before it started to pour down rain. Nothing seemed wrong but was unable to check out everything. Its just a heavy clunk when i press the gas from a stop. If im really gently then it barely if at all does it.
Im stumped but will keep updating.
  • 11 months later...
I have a 2009 Yukon Denali that seems to have the same issue. Upon a firm acceleration, there is a "clunk" or sometimes a "clunk clunk" from somewhere in the front. Cant tell if its right side, left side or the middle.  It makes a similar noise (may or may not be the same noise) when going over a speed bump (or in my case the end of my driveway). I've tried a hard acceleration with my foot on the brake and there are no noises to report so I don't think the engine mounts are involved.  Any additional thoughts or solutions?
  • 3 years later...
I have a 2011 gmc sierra that the front wheel has a popping sound on fast eccellration. I have replaced upper and lower balloons and tierod ends and control arms and new brakes and disc . I have spend $3500.00 what else could it be.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 654 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
