Yes yes ive looked before anyone comes at me.
Im not a member yet bit i do need help.
My yruck is a 2012 Sierra Denali 1500. It has 140k miles and ive noticed that only from a dead stop when i push the gas it clunks. It also feels like there is a delay to when the front wheels catch. Im not sure what it is and any suggestions would be appreciated.
Thank you
You mean release,not catch? probably got to inspect brake pads for binding,a little sanding on pads and pad slide area,a touch of antiseize
First off, welcome to the club. We are mostly adults and understand the search function sucks. But if you need someone to get upset at you, head on over to GMfullsize.
This can be caused from a couple of different things but is prolly a combination of a group of things wearing out.
If the upper and lower ball joints are failing you will get this feeling as everything is shifting position prior to the wheels starting to roll. Ball joints are common on this year of GM truck and are easily serviceable. It is my recommendation to always replace tie rods when doing this as you will almost always need them done shortly after and you will save on labor to replace them now.
Could also be the brakes or other suspension related issue. The sway bar end links just about fall apart when they left the showroom floor.
If you can, get the front end off the ground and us a pry bar to move everything around. Lift up on the tires, wiggle back and fourth and side to side. If you can get it to pop you can locate the noise.
Another option is to stand outside and listen while someone operates the unit and see if you can here the noise a bit closer.
Your username cracked me up and indicates that once you fix the issue you wont return, but I hope to here back with the diagnosis.
Edited by Mikebtte
Thank you mikebtte and jetmek.
Im going to look it all over this weekend and whatever i find ill let you know.
Oh no. Don't you worry. I will be back with a thousand more questions and my username will stay exactly the same.
Thank you again for all the help. Will report back in a few days.
So i went through what i could before it started to pour down rain. Nothing seemed wrong but was unable to check out everything. Its just a heavy clunk when i press the gas from a stop. If im really gently then it barely if at all does it.
Im stumped but will keep updating.
  • 11 months later...
I have a 2009 Yukon Denali that seems to have the same issue. Upon a firm acceleration, there is a "clunk" or sometimes a "clunk clunk" from somewhere in the front. Cant tell if its right side, left side or the middle.  It makes a similar noise (may or may not be the same noise) when going over a speed bump (or in my case the end of my driveway). I've tried a hard acceleration with my foot on the brake and there are no noises to report so I don't think the engine mounts are involved.  Any additional thoughts or solutions?
  • 3 years later...
I have a 2011 gmc sierra that the front wheel has a popping sound on fast eccellration. I have replaced upper and lower balloons and tierod ends and control arms and new brakes and disc . I have spend $3500.00 what else could it be.
    btm
    btm
  • Who's Online   2 Members, 0 Anonymous, 1,298 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
