Headlights
ScottRupert
If you adjust it up or down it will do the same to your low beam. Is the high beam too low or high? You could adjust it and then adjust the low beam to the height you want using washers on the low beam projectors.
Sent from my SM-N950U using Tapatalk
My high beams are too high. I thought the adjustment screw was just for the low beam.
Correct. If your highs are too high then lower them via the adjuster. The add some washers in the top screw holes of the projector to raise it up.
