17 inch rims on a ltz
mkeddie
So I know the lower lvl trucks have 17 available...
Are the brakes bigger on the ltz and high country that make it so u can't put 17s on
Plan on mounting 17s for snow tires if I can
Sent from my Moto Z (2) using Tapatalk
Brakes are the same on all 2500s.
#iworkforGM
Thanks
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
