Dual Battery Questions
Ducky
The Redarc is supposed to take care of it, but I really don't want to spend that much(and I've already got a new PAC-200) - as I'm not gonna put a super expensive battery in as secondary.  And, in the end, the load on that battery is not going to be super great usually either - I just like the piece of mind having it to power things in the back of the truck for work.
Here's a link to the unit I'm talking about
https://www.amazon.com/REDARC-BCDC1225D-Dc-Dc-Charger-12V25a/dp/B077JPHCRV
What do you plan to power from the batt and how long?
Sent from my LG-G710 using Tapatalk
  • Replies 48
Ah ok. In all seriousness I'd do a 2 battery bank separately just for that. That would give you the off time your looking for without draining batt life down too much. I'd go (2) 3100 series batts if the funds were available. Given you say it wouldn't be that often it might not be worth it.
For what its worth~ no automotive alternator will actually charge a batt to a complete charge. Only what a manufacturer designs it to be. To test this wait until you feel a batt is charged. Then connect it to a excellent stand alone charger. It'll charge a little bit more. I bet...
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,230 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
